As I mentioned before, the Connect radio cuts off if it doesn't sense a load on the speaker wires. If you have the wires cut in order to feed a DSP or AMP, it will shut the signal off.
Today I worked around that problem. I used 5w 47ohm resistors in parallel with the speaker wires going into the DSP. The DSP feeds the amp and the amp feeds my aftermarket front speakers. Once I get it all cleaned up, I'll post more pics.
But basically, I tricked the system! Wooohooooo! Aftermarket audio glory!
