1 - 17 of 17 Posts
Well it finally happened jeep started for work this morning started after work started at the grocery store twice for quick stops get home and it doesn’t want to start all kinds of warnings going off!!! Right now trying the battery disconnect for 30 minutes hoping that will work if not will have to wait till Friday to get a battery
well you can have les schwab do the free battery test and go to wilder and get a mopar if its defective
at least les schwab has a better selection and heavy duty options nothing like a 7yr warranty and if it goes bad sooner you get credit
Discussion Starter · #9 ·
I just saw that andLes schwab has always been good
Discussion Starter · #12 ·
Ops
I took your adivse and went to les schwabs this monring and got it tested they said it was only holding 2/3 of its actual capacity.
I had them replace with an AGM battery to the tune of 278.00
I'm glad that was it.
I know when I looked at the gauge it has read 14.8v but I haven’t monitored it lately and not knowing the last time it was replace
Reading the voltage doesn't do it. You have to do a load test (which is what I assume Les Schwab did).
If that's the original battery from 2015, you're very lucky it lasted this long. Three years is the norm.
Discussion Starter · #15 ·
yes they did a load test best that i know. it was a white top mopar battery im assuming that it was the orginal.
1 - 17 of 17 Posts
