1 - 7 of 7 Posts
Hi I have a jeep renegade 215
And have a problem with it had a test
2 faults
P0130. 02 sensor bank 1
Mode 7 sparadic errors.
what do I do what does this mean
Hello.
I think it's the lambda sensor. I'd try a google on the code wrt Fiat cars as you may get more info from that search.
2 faults
Upstream O2 Sensor (the one in the Catalytic Converter).
I would change the O2 Sensor first, soon.
A faulty O2 sensor will cause other secondary codes due to the Power Control Module (PCM) making adjustments to compensate for the false reading.
Bienvenue!
It is marked in the above photo by the blue circle.
You can also find it on this article about the 500L:
1 - 7 of 7 Posts
