1 - 5 of 5 Posts
Standard and optional features:
  • 9-1-1 call/Assist Call: Mirror-mounted buttons for emergency services, roadside assistance, Uconnect Customer Care and non-collision related emergencies
  • All-row full-length side-curtain air bags: Extend protection to all outboard front- and rear- seat passengers. Each side air bag has its own impact sensor that autonomously triggers the air bag on the side where an impact occurs. This type of air bag is housed in the headliner just above side windows
  • All-speed traction control system
  • Anti-lock brake system with rough-road detection: Anti-lock brake system is capable of detecting if the vehicle is driving on a rough road by the oscillations in the wheel speed signals. Rough road is detected on off-road surfaces or trails, and ABS enters a different pressure control where it will hold the brake pressure for longer pulses
  • Automatic defog: Enables the Renegade’s automatic temperature control (ATC) system to measure humidity inside the vehicle and provide a fog-free windshield automatically
  • When equipped with the power-sliding My Sky roof, the system automatically reverses when it senses an obstruction during closing
  • Windows automatically reverses when it senses an obstruction during closing
  • Blind-spot Monitoring (BSM): Uses dual ultra-wideband radar sensors to aid the driver when changing lanes or if being passed by or passing unseen vehicles. The system notifies the driver of vehicle(s) in their blind spot via illuminated icons on the side-view mirror and with a driver-selected audible chime
  • Brake assist: In an emergency brake situation, the system applies maximum braking power, minimizing the stopping distance
  • Brake-lock differential system (BLDS): Allows the vehicle to maintain forward motion if one or two wheels lose traction by selectively and aggressively applying brakes to the spinning wheels
  • Brake-throttle override: Allows driver to stop the vehicle when throttle and brake inputs occur simultaneously; electronic throttle control reduces engine-power output until vehicle stops or pedal inputs cease
  • Brake traction-control system (BTCS): Helps to keep driving wheels from spinning during acceleration from a stop or during slow speeds by applying individual brakes to the slipping wheel(s)
  • Capless fuel-filler door: Provides fuel-filling simplicity and eliminates contact with any fuel spillage
  • Constant-force retractors (CFR): Regulates the force exerted on the occupant by the seat belt and then gradually releases seat-belt webbing in a controlled manner
  • Driver’s side knee air bag
  • Dual-note electric horns: Produces two different tones as the same time, similar to better cut through ambient noise better
  • Enhanced Accident Response System (EARS): Makes it easier for emergency personnel to see and reach occupants in the event of an accident by turning on the interior lighting, flashing the hazard lights and unlocking the doors on the Renegade after air bag deployment. Also shuts off flow of fuel to the engine
  • Electric parking brake (EPB): Utilizes parking brake switch mounted in the center console, a motor on caliper (MOC) at each rear wheel and an electronic control module. Four modes of operation: static apply and release, dynamic apply, drive away release and safe hold
  • Electronic brake-force distribution: Assists the driver to optimize stopping distances and control under all vehicle loading conditions by regulating braking pressure front-to-rear
  • Electronic locking fuel filler door: Prevents theft or tampering of the gas cap which can lead to inefficiency and unwanted release of fuel vapors (outside North America)
  • Electronic roll mitigation (ERM): An extension of electronic stability control (ESC). Uses input from ESC sensors to anticipate if the vehicle is at risk of entering a potential roll situation, then applies the brakes individually and modulates the throttle position as needed
  • Electronic stability control (ESC): Enhances driver control and helps maintain directional stability under all conditions. Provides the benefit in critical driving situations such as turns, and is valuable when driving on mixed surface conditions including snow, ice or gravel. If there is a discernible difference between driver input through the steering wheel and the vehicle’s path, ESC applies selective braking and throttle input to guide the vehicle back on to the driver’s intended path
  • Express up/down windows: One-touch powered express up/down window button located on the front driver and passenger-side door
  • Forward Collision Warning-Plus: Utilizes radar and video sensors to detect whether the Renegade is approaching another vehicle or large obstacle in its path too rapidly and warn or assist the driver in avoiding/mitigating the incident
  • Front seat-belt pretensioners: During a collision, impact sensors initiate front seat-belt pretensioners to remove slack in the seat belt system, thereby reducing the forward movement of the occupant’s head and torso
  • Front-seat mounted side pelvic thorax bags: Provide enhanced protection to the driver and front outboard passenger in certain impacts. Each side air bag has its own impact sensor that autonomously triggers the air bag on the side where an impact occurs. Standard side air bags are housed within the outboard side of each front seat
  • Front wiper blades deicer: Prevents wiper blades from freezing to the front windshield, and improves cold-weather wipe ability
  • Hill-start Assist (HSA): Assists drivers when starting a vehicle from a stop on a hill by maintaining the level of brake pressure applied for a short period of time after a driver’s foot is removed from the brake pedal. If throttle is not applied within a short period of time after the driver’s foot is removed from the brake pedal, brake pressure will be released
  • Hill-descent Control: This feature allows Renegade to descend steep grades with minimal driver input
  • ISOFIX: Designed to ease installation of compatible aftermarket child seats
  • LaneSense Departure Warning-Plus: Plus leverages electronic power steering (EPS) to deliver a torque-input to alert and assist the driver with corrective action
  • Occupant Restraint Controller: Detects an impact and determines whether a crash is severe enough to trigger air bag deployment and whether the primary or secondary stage inflation is sufficient. In addition, the controller detects side impacts and determines whether the rail-curtain and side seat-mounted (thorax protection) air bags should deploy. Engagement of front seat-belt pretensioners are also managed through the controller
  • ParkSense rear park assist system: The system utilizes ultrasonic sensors at low speeds in reverse to detect stationary objects. If it is determined that a collision is imminent the system will provide a momentary, autonomous brake apply/brake jerk then release. At speeds below 7 kph the system will bring the vehicle to a stop before releasing
  • ParkView rear backup camera: Provides a wide-angle view of the area immediately behind the vehicle, giving the driver greater peace of mind before reversing at low speeds. Contains dynamic grid lines to aid the driver when maneuvering into parking spaces or narrow areas. Also aids in lining up a trailer to the vehicle’s trailer hitch, when so equipped. The image is displayed on the navigation screen when the transmission is shifted into Reverse
  • Rain-sensing wipers (outside North America)
  • Ready Alert Braking (RAB): Anticipates situations when the driver may initiate an emergency brake stop and uses the ESC pump to set brake pads against rotors in order to decrease the time required for full brake application
  • Rear Cross Path (RCP) detection: In parking lot situations, this system warns drivers backing out of parking spaces of traffic moving toward their vehicle. It activates any time the vehicle is in Reverse. The driver is notified of vehicle(s) crossing behind the vehicle via illuminated icons on the side-view mirror and with a driver-selected audible chime
  • Sentry Key engine immobilizer: Utilizes an engine key that has an embedded transponder with a preprogrammed security code to discourage vehicle theft. When the key is inserted into the ignition, the controller sends a random number to the transponder and the engine is allowed to start. If an incorrect key is used, the engine will shut off after a few seconds
  • Supplemental turn signals: Signal lamp built into the housing of exterior mirrors allows turn signals to be viewed from the front, as well as the sides and rear of the vehicle in order to alert oncoming traffic and pedestrians
  • Tilt-and-telescoping steering column: Allows steering column to tilt and move toward or away from the driver to achieve a safe and comfortable distance from the advanced multi- stage front driver air bag, if deployed
  • Trailer-sway control (TSC): Reduces trailer sway and improves handling in adverse towing conditions caused by crosswinds and traffic. The system monitors the vehicle’s movement relative to the driver’s intended path, then applies alternating brake pressure to slow the vehicle and then increases the pressure on one front wheel in order to counteract the sway induced by the trailer
1 - 5 of 5 Posts
