I got this from the Chrysler site (link below) - nice explanation of both engines:
2.4-liter Tigershark engine with MultiAir2
Efficiency and refinement also are hallmarks of Chrysler Group’s 16-valve, 2.4-liter Tigershark I-4 engine with the MultiAir2 electro-hydraulic, fully variable valve-actuation system. The high-tech engine produces 184 horsepower, 177 lb.-ft. of torque and is paired exclusively with the segment’s first nine-speed automatic transmission on 4x2 and 4x4 models.
MultiAir technology, which is exclusive to Chrysler Group in the North American market, uses a column of oil in place of the traditional mechanical link between the camshaft and intake valves. The resulting precision maximizes intake manifold pressure, significantly reducing pumping losses.
MultiAir2 takes the innovation further by simultaneously controlling both valve opening and closing events to more effectively manage combustion quality. This ensures the appropriate, effective compression ratio and efficient internal exhaust-gas recirculation (EGR) for improved fuel economy.
Refinement was a key consideration in the design of every Tigershark component, from its fully isolated aluminum head cover with integrated oil-separation system, to its high-pressure, die-cast aluminum block.
Sandwiched between the block and the steel oil pan is a lightweight, aluminum ladder-frame with integral oil filter and oil-cooler adapter. This lends additional structural rigidity.
The oil pan itself boasts refinement. Acoustic material is sandwiched between its outer and inner stampings.
The Tigershark’s polymer-coated piston skirts and tighter piston-to-bore tolerances contribute to reduced NVH. The cast-aluminum piston, combustion chamber and ports align with the MultiAir2 system for optimal combustion and fuel economy.
Cast-aluminum pistons with a compression ratio of 10:1 are designed specifically for the engine and MultiAir system.
Each bore is fitted with individual oil-squirters in the block that spray oil on the bottom of the pistons and bore walls to maintain cylinder-wall and piston temperatures. This feature also helps prevent hot spots that could lead to knock, while improving performance and fuel economy.
Fitted to the forged-steel crankshaft are powder-forged-steel connecting rods that feature a full-floating piston pin with diamond-like carbon coating. This further reduces friction and improves fuel efficiency.
Vibration is minimized with the use of a balance shaft module. And to maintain adequate oiling at all engine speeds, the 2.4-liter MultiAir2 Tigershark features a two-stage oil-pressure relief system that reduces engine-oil pumping loads at low engine speeds for better fuel efficiency.
Other key features of the 2.4-liter MultiAir2 Tigershark I-4 engine include:
- 360-degree engine-to-transmission attachment
- Coil-on-plug ignition with dual precious-metal spark plugs
- Front-end accessory drive with automatic tensioning single-belt drive
- Tigershark delivers reduced operating costs because its cam drive, cam-phasing and valve-train components require no scheduled maintenance
1.4-liter MultiAir Turbo engine
Paired with a six-speed manual transmission, the 1.4-liter MultiAir Turbo four-cylinder engine generates 160 horsepower and 184 lb.-ft. of torque to provide a spirited driving experience on Jeep Renegade Sport and Latitude 4x2 and 4x4 models.
The new 1.4-liter MultiAir Turbo engine transmits its power through high-strength components throughout the drivetrain, including equal-length half shafts and a 4.438 final-drive ratio.
Structurally, the 1.4-liter MultiAir Turbo engine starts with a durable cast-iron block and a structural aluminum bedplate. The bore and stroke are 72 mm and 84 mm, respectively, for a total displacement of 1,368 cc.
Boost pressure is dynamically managed to provide a broad torque curve over a wide variety of ambient conditions, with a peak pressure of 22 psi at 4,000 rpm.
Exclusive MultiAir valve-actuation technology controls intake air, cylinder by cylinder and stroke by stroke. The resulting precision reduces carbon-dioxide emissions and boosts fuel-economy up to 7.5 percent compared with engines equipped with conventional valvetrains.
At the bottom end, a forged-steel crankshaft with select-fit main bearings is supported across five main journals. The crankshaft and its counterweights are designed to reduce overall mass.
Durability is ensured with the use of lightweight forged-steel connecting rods that have been designed with a unique cross-section to minimize longitudinal and lateral rod-bending.
Lightweight cast-aluminum pistons contribute to the overall efficiency of the reciprocating assembly and the engine’s high-rpm capability. Full-floating piston pins are used for added strength.
Piston cooling jets, located at the bottom of each cylinder, contribute to fuel economy by squirting oil on the bottom of the pistons. This helps maintain cylinder temperatures and reduce the possibility of hot spots along the cylinder walls or at the top of the piston that could lead to spark knock.
Proven, fun-to-drive six-speed manual transmission
All-new 2015 Jeep Renegade Sport and Latitude models equipped with the standard 1.4-liter MultiAir Turbo feature a six-speed manual transmission with 6.68 ratio spread and a 4.438 final-drive ratio for fuel efficiency at faster speeds. And thanks to its first-gear launch ratio of 18.4:1, the gearbox delivers quick acceleration with smooth, precise shift quality. A tubular intermediate shaft with equal-length half shafts helps mitigate unwanted torque steer.
http://media.chrysler.com/newsrelease.do?id=15531&mid=444
