1 - 8 of 8 Posts
Two diminutive city crossovers, two vastly differing approaches. One is a yank tank focused on rugged construction, the other is bloated Mini focused on the sporty side of the equation.
I've compared here the base trim Countryman to the base trim Renegade, as well as the top trim Countryman and Renegade. I've used UK specs for the Countryman and UK engine options for the Renegade...
Jeep Renegade:
Engine: 1.6L E Torq
Power: 108 @ 5,500 RPM
Torque: 112 @ 4,500 RPM
Length: 4,231 mm
Width: 1,803 mm
Height: 1,689 mm
Boot Capacity: 523 Liters
Mini One D Countryman:
Engine: 1.5L I4
Power: 97 hp @ 6,000 RPM
Torque: 113 lb-ft @ 3,000 RPM
Length: 4,097 mm
Width: 1,789 mm
Height: 1,561 mm
Boot Capacity: 350 Liters (max 1,170 L)
Jeep Renegade Trailhawk:
Engine: 2.4L Tigershark I4
Power: 184 HP @ 6,400 RPM
Torque: 108 @ 5,500
Length: 4,231 mm
Width: 1,803 mm
Height: 1,739 mm
Mini John Cooper Works Countryman:
Engine: 1.5L I4 Turbo
Power: 218 HP @ 6,000 RPM
Torque: 193 lb-ft @ 1,850-5,600 RPM
Length: 4,133 mm
Width: 1,789 mm
Height: 1,549 mm
It's obvious which will be the favourite here ;)
Jeep Renegade:
Engine: 1.6L E Torq
Length: 4,231 mm
Width: 1,803 mm
Height: 1,689 mm
Engine: 1.5L I4
Length: 4,097 mm
Width: 1,789 mm
Height: 1,561 mm
Torque: 108 @ 5,500
Length: 4,231 mm
Width: 1,803 mm
Height: 1,739 mm
Length: 4,133 mm
Width: 1,789 mm
Height: 1,549 mm
I'm more than a little surprised MINI hasn't gone to the new engines for the Countryman. That would mean turbos on everything and 1.5 3cyl for the granny engine and 2.0 for the big engine... and bigger injectors and turbo for the JCW.
Countryman moves to the new MINI platform and engines next year; 2015 was just a refresh.
Sent from AutoGuide.com Free App
1 - 8 of 8 Posts
