1 - 13 of 13 Posts
Sometimes I can't open the door by pressing the button on the key fob. I open the door with the mechanical key - car starts normally. Afterward I can lock the door with the fob. After some time this happens again. Sometimes the car asks to push the start button with the fob. Next time it just starts normally.
Twice I checked this using the spare fob which I just left in a drawer for two years. If the door doesn't open when I use the regular fob it will not get opened with the spare fob as well. This seems to exclude the possibility that drained battery in the fob caused the problem.
Any idea?
First thing I would do is change the battery in the fobs.
But why the battery in the spare fob which I never used would die? Or may be even when it lays in my cupboard it sends radio signals?
Anyway I opened the fob that I regularly used and the battery measured 2.98 volt.
It should read 3.0 Volts. Your Jeep will not start with 11.98 volts same thing.
Any idea?
Hello Simkins,
If you are unable to remedy this concern with the assistance of fellow forum members, I kindly suggest connecting with your local Jeep dealer. If you are in need of any assistance with that process, please feel free to send us a private message.
Laura
JeepCares
Discussion Starter · #9 ·
my 17 was doing same thing.....took it in and they flashed bcm I think...anyways no problem in a few months
Will be funny if it is just the battery in the remote. Will have to wait couple weeks to tell for sure.
At any rate using a spare remote is not a proxy for replacing battery. Since the battery in my spare unused remote measured the same 2.98 Volt as the one in the regularly used remote. Apparently this is because the radio receiver in the fob is always on expecting a signal from car. And this drains the battery.
I changed both fob batteries first and still same problem....so they flashed the bcm and gone ...no problems....good luck
Discussion Starter · #11 ·
It is enough to change the battery in one fob to tell if this is the problem.
In my case two weeks passed and everything works fine, no recurrence. So it was the fob battery indeed.
However had I bring the car to the dealer they would surely do with it something clever and sophisticated.
At this rate we will all be installing small solar panels to the windscreen just like I do with my boat. :oops::oops::oops:
2017 Jeep Renegade Trailhawk
I had a similar issue recently. Took it to the dealer and they replaced the radio frequency handler (RFH) and both key fobs. I have a warranty, otherwise it'd be an expensive bit of maintenance.
1 - 13 of 13 Posts
