1 - 6 of 6 Posts
I installed a 2 inch Rough Country lift kit and I want larger tires. What is the largest size I can go to ?
235/65/17 will work fine. I run a 21 Renegade for a work vehicle. I have the RC 2in lift kit installed also. You should look into the Nokian Rotiva as your tire choice, which is what i run. PHENOMENAL tire. It will be ending production soon, being replaced by the Nokian Outpost. DO YOU RESEARCH, you will not be let down.
Thanks , I'll look into those tires.
1 - 6 of 6 Posts
