So I've done this in a Scion tC, Toyota Tacoma, and Scion FRS. I pulled the Renegades dash out and it turns out the Renegade uses the same type of LEDs. The Renegade uses 3 different sizes of LEDs on the cluster.
*Be warned that this requires steady hands and soldering skills. The LEDs are so small that you will need tweezers to work with them. The solder will need to have a sharp pointed tip as well.
I do not have a after shot of the cluster yet, because I just opened it up to figure out the light setup in the cluster, so that I know what type of LEDs to buy. I am only going to change out 6 LEDs that light up the numbers and dashes between. All the warning lights will be left stocked. I've changed the warning lights out before on the other cars with great results, but I decided that the Renegade's setup didn't require it. The main center console I did not what to get into to change. It might not even be possible to change it because it looks to be a large LCD screen.
Here is the how to remove the cluster. To install is in reverse order.
Here are the tools you will need to get the cluster out and take it apart.
Torx male size T10 (A long screw driver handle and a short one)
Torx male size T8
Antenna telescoping magnet
2 Spoons
Pliers
To remove/replace the LEDs you will need these.
Soldering iron with a pointed tip. (one that has a removable tip makes all soldering jobs easier.)
Soldering medium
Tweezers
Adjust the seat and lower the steering wheel all the way down to make room to remove the cluster.
Pop these tabs out with a small flat head screw driver. Be careful because these tab covers are soft and can break. I used 2 small flat head screw drivers to get them out. One to hold the tab/clip and the other to pry and pop it out. Look at the picture with the screw driver in the tab cover, this shows where to pry the tab/clip back, so that you can pop it out. Use a short handled screw driver with a size T10 torx head to remove the screw.
After removing the 2 screws on the upper side of the cluster trim, it is still held on with 4 snap in tabs. 2 on the top side and 2 on the bottom side. Just grab the cluster trim where you can and pull it straight out towards you. View the picture of how the tabs look and where they are located.
The trim off.
Next remove these 2 size T10 torx screws, so that you can move the pleather steering column cover out of the way. This will make room for removing the cluster and make access to the 2 lower screws holding the cluster on. The pleather steering column cover can't be removed, unless you remove the steering wheel column cover as well, but you will not to remove it. Just move it out of the way.
Once the 2 T10 screws are removed, the cover is still held in with 2 clip on tabs. Again, pull the trim piece back and out towards you. Here is where and how the tabs look like.
Fold the trim piece back and in half.
Next, located the 4 T10 torx screws holding the cluster in place. There are 2 on top and 2 on the bottom. Use a magnetized T10 screw driver or use an telescoping magnet antenna to pull the screw out after loosening it. Try very hard not to drop the screws down the dash. To install these screws back on, use the telescoping magnet and start to screw the screw in 1 or 2 threads. Then tighten it with the T10 screw driver.
So far all of these screws are size T10 screws and they are all exactly the same. So you don't have to keep track of which one goes where.
Once the screws are removed, you can pull the cluster out. I finally find a cluster that can easily be removed out of the dash, yipee! A lot of the newer dashes only use 1 plug vs older cars. Other models use a push tab to remove the plug, which makes it hard to press to remove. And the wiring harness is very short, so it's hard to see how to remove the plug. The Renegade uses a long harness that lets you pull it out to easily access the plug. The plug uses a soft tab with a hold down lever that comes off very easy. Push the tab holding the red hold down lever in place and pull the red lever up and around. The plug comes out very easy after that.
Now the cluster is out and we can start working on taking the cluster apart to get to the LEDs.
Torx male size T8
2 Spoons
Pliers
Soldering medium
Tweezers
The trim off.
