1 - 17 of 17 Posts
Read Only
Does anybody have the correct info on LEDs read all post and am more confused. The only lights on the bulb warning signal are the outside lights which I am sure would have to be replaced with CANBUS LED bulbs. The inside lights are not on any warning indicator, so I assume they can be regular LED replacements. Somewhere on the posts it stated the cargo lights can be, but the map lights, dome light, glove box should be CANBUS, that doesn't seem correct. Can some help with the correct info sure it would help .
Thanks to anyone who can help.
2019 Jeep Renegade
So my experience with the conversion to LED (2019 Latitude) was that the CANBUS error-free headlights, reverse lights, front side marker lights and fog lights work great with no errors. I have the DRLs, front and rear turn signals coming this week (5/7). The rear side marker lights are not replaceable; I believe they are a wired-in LED.
I am having the same error with the license plate lights; every one I have tried throws the error. I am guessing resistors are going to be needed unless someone has found a bulb that will work. I thought of trying a 194 CANBUS error-free with multiple LED chips (more than 3) in it because it should necessitate the need for more current to the socket.
On the interior, I used CANBUS error-free 194s in the two map lights, the dome light, the glove box light and the cargo area light. Again all five of those produced zero errors.
Thoughts or additions anyone?
Rich
Update:
The bulbs arrived. Rear cargo bay light, interior passenger light, front courtesy lights have all been replaced with LED.
Beware! When you say regular LEDs and do not make the mistake as I did and buy the long LEDs with the metal at each end that look like big fuses. No need to guess that they are the wrong ones.
ps: Forget any ideas of trying to unhook the clear lens and replace the courtesy lights. It only took about 1 minute to remove the whole panel. 2 clips at the front and 1 at each side then the panel drops out. You dont even need to bother unhooking the harness plugs as the bulbs are contained within a housing that has 2 finger press clips to release it from the rear. Simply use a credit card to slide out your bulbs. If I can offer one tip it is that you leave the ignition in the on (MAR) position and your courtesy lights switched ON. For whatever reason the bulbs illuminated immediately as opposed to 30 minutes fannying around trying to work out if the were duds.
The link, if clicked will show you what I used and all lights are working with no errors.
LED courtesy bulbs canbus free
Did you change out your tag lights? I have the 2020 and get message about tag light out even when it is not.
Update:
2019 Jeep Renegade
What bulbs did you use for brake and rear turn signal lights? Did you have to install resistors? Any bulb out errors?
2019 Jeep Renegade
So I started to change out the interior bulbs to LED on my wifes 2020 Renegade yesterday.
I'm not trying to advertise in anyway. But I purchase all of my leds from VLEDS....I have had no issues, no need for resistors on every car I've owned. They are a little pricey, but you get what you pay for.
First the dome light - Every single bulb guide i found online shows the dome light bulb to be a 6418 (fuse type) bulb. But after pulling the bulb yesterday I found it to be a simple 194 (wedge type).
Map lights - I tried so hard to pull the whole overhead console out, but I could only break 1 corner free. Im going to try to just pop out the lens.
Cargo and glove box were a piece of cake. All with no errors.
Sent from my SM-G973U using Tapatalk
1 - 17 of 17 Posts
