I see Italy has a lift it; Would it fit my US trailhawk? If not does anyone know of any US liftkits? Thanks
I was just looking under the back of my TH and thought the exhaust pipe looked kinda exposed. Seems to be the lowest-hanging part back there.I originally intended to lift my Trailhawk. I have found the factory clearance sufficient for most anything I can throw at it. I do have an extra 1/2-3/4" due to a little bigger tire, but the only obstacles I've had to turn around at were due to lack of power. I think once a more aggressive tire is put on, the low powered motor quickly becomes the limiting factor, not clearance.
Be careful with departure angle. Due to the placement of the exhaust path, it is possible to "crimp" the exhaust tube just before the muffler between the chassis and the rear suspension. Luckily it's a quick and inexpensive ($30) repair, but it limits the departure angle to lower than the published specs.
