https://www.jeep.com/assets/pdf/renegade_spec.pdf
(this PDF should really be put in a sticky note somewhere as it answers tons of questions)
Actually you can add the decal to any model, it's $185 MSRP. There are also other additives worth checking out at the link below.and I also really like the hood decal (only available on the TH, yes?).
Other than the visual package, the simple feel of the car is totally different. The trailhawk has more of a Jeep feeling drive to it if that makes sense. A little more rugged and rough around the edges. Drive both and decide what you want. As for the stripe, you can add a decal to any car.Please forgive my ignorance, but until now, I'd pretty much decided on a Trailhawk in Commando Green or Anvil. I don't do tons of off-roading, though my travels do take me down lots of dirt/gravel (untrodden paths, so to speak) and I live in the northeast, so snow. I like the little bit higher profile of the TH, and especially the full-size spare (never been fond of the the newer itty bitty tires - just seems wrong to have but a few inches between me and the road) and I also really like the hood decal (only available on the TH, yes?). And I know Anvil is only available on the TH, but I think I'm fine with the Commando Green.
However, I'm seeing some Latitudes come through that are configured the way I want them, i.e., with navigation. Honestly I could care less re: back up cams and all that stuff and though I'd like to have MySky, I could live without it.
So - dilemma - and I do need a new car, say, within three months. I'm fine waiting to see what else comes through over the next couple of months, but what am I really gaining with the TH that I won't have with a 4WD Latitude?
Can someone enlighten me?
You woz robbed. It does not have low range or diff lock.I bought a TH a couple of months ago and decided to go with the TH because it has a high/low range transmission plus diff lock, hill descent, and a Rock mode selection, not that I will use any of that. Plus it has skid plates and has an oil cooler which comes standard on the TH and Limited and I think it is included when the tow package is added at the factory since it is recommended when towing.
If you have a TH and it does not have 3 buttons in mode selector knob; AWD/LOW, 4WD/LOCK, and an icon of hill dissent then you were robbed, or those functional buttons are there just for show. The Limited, Latitude, and Sport do not have those buttons in the mode selector knob.You woz robbed. It does not have low range or diff lock.
It is still possibly able though.
I love mine so far![]()
Most concise explanations I could find:You woz robbed. It does not have low range or diff lock.
http://www.allpar.com/SUVs/jeep/renegade.htmlThe Trailhawk also gets a special four-wheel-drive system dubbed Active Drive Low. Rather than using a two-speed transfer case with a low range, the Trailhawk uses its 4.33-to-1 axle ratio and the nine-speed automatic's short gears to achieve a 20-to-1 crawl ratio for off-roading. Hill descent control is standard, and I like how the system lets you adjust the descent speed using the gas and brake pedals.
Rock, on Trailhawk only (because it is only available in low gear), is similar to Mud/Sand but increases brake lock differential capacity, and locks the differential.
http://www.cars.com/jeep/renegade/2015/expert-reviews
Same for me, I got a Latitude & kind of wish I had waited for a Trailhawk. I took it out on a trail last weekend & had a blast with it, but mine didn't come stock with any tow hooks, spare tires, etc., so I'll have to add everything aftermarket myself...might as well have spent the money up-front. But I got a pretty decent deal on a loaded Latitude, which I am very happy with, and I can always upgrade later!Just purchased a Jeep Renegade Latitude, got a great price on it although after reading more I think I may have been screwed. Planning on doing quite a bit of off roading with the Jeep and had the dealer tell me the latitude would be perfect for it. I had considered the trailhawk although the roof was taller than I would have preferred for putting stand up paddle boards on it. The dealer told me that they were the same capabilitys the trailhawk just had tow hitch and pull hooks on it and larger tires.
They are installing the towhitch, new bumper and tow hooks this week for free....what do you all think should I return the vehicle and go with the trailhawk from another dealer? Or will the latitude be ok for the off road needs?
the latitude is closer to being a car while the trailhawk is made to go off road. if you plan to go off road, why would you settle for anything less than a trailhawk.Just purchased a Jeep Renegade Latitude, got a great price on it although after reading more I think I may have been screwed. Planning on doing quite a bit of off roading with the Jeep and had the dealer tell me the latitude would be perfect for it. I had considered the trailhawk although the roof was taller than I would have preferred for putting stand up paddle boards on it. The dealer told me that they were the same capabilitys the trailhawk just had tow hitch and pull hooks on it and larger tires.
