I had the same issue with the locks. There are a few TSBs that will take care of some issues. Once the dealer plugs your car into their computer the TSBs should come up but if not I have attached the service record with the TSBs that were updated.UPDATE: disconnecting the battery worked, for now. I love this car, otherwise I wouldn't put up with the issues, but I think I'm reaching my end. I just don't trust it.
Dead/weak battery in the key fob maybe?once for me, couple days ago. i have the keyless System. grabbed ed handle and nothing, buttons on both key fobs did nothing. used emergency key which set off alarm.button wouldnt start. had to use the dead battery procedure of pressing fob agsinst button. this worked. once started dash kept displaying fob has left area. tried turning car off and same thing, nothing worked. drove home and now everything works fine?
no had both key fobs with us, couldnt be both at same time. was really weirdDead/weak battery in the key fob maybe?
I have exactly the same problems with my 2015 Limited Renegade. Yesterday I could not open any doors, not even from the inside except the drivers door that I had to use the real door key to open/lock.Update/Clarification (since I can't figure out how to edit a post)
I am still waiting on the dealer to setup an appointment time to have my locks reprogrammed. I called yesterday, but haven't yet heard back. In the meantime, I wanted to see if disconnecting the battery works and it does (kind of). I disconnected the negative from the battery, as the positive seems a little more involved. It did allow the locks to start working; however, once I locked and unlocked the vehicle 2 times each way, it stopped working. I repeated the process and same result. The final time I did it only once to confirm, turned it on for a bit and now letting it sit, thinking maybe that is the magic part.
For clarification, the lock issue has affected the following:
- Key remote unlock/lock not working (though it does send the honk signal for locking)
- Door lock/unlock buttons not working (you have to manually flip the switch for each door)
- Locks to not automatically engage when driving (safety issue here as I have kids)
- The trunk; however, is not affected and locks/unlocks with the key remote (not sure if the door lock buttons do the same).
