1 - 6 of 6 Posts
Has anyone found errors in the owners handbook ?
page 116:
stop / start system
LED off: system deactivated
LED on: system deactivated
(LED off is system activated)
page 206:
Fluids and Lubricants
lubricant for petrol engines
SAE 0W-30
search online and it states 5W-40
5w-40 is correct for multi air. Same as Alfa.
I don't think you are correct as late model Giuletta 1.4 MA's now uses 0W-30, so I would assume the same for the Renegade (Euro 6 ??). Best to double check with the dealer.
I also checked the Alfa Forum as I am also a member using the same user name, later Alfa MA's use 0W-30
Thanks despite being on AO since way back I didn't realise this. Ok so Fiat have reduced the high temp viscosity since 2013. I have the TBI, same oil, but I guess Fiat needed to meet the euro 6 regs ... absolutely go with what Jeep say, there can be no quibble with the warranty then.
1 - 6 of 6 Posts
