1 - 3 of 3 Posts
vBToucan.com Vendor
Take advantage of the thermal energy in your Jeep Renegade and improve performance with the SILA Concepts Turbo Blanket.
We all know that heat soak will reduce power and performance but what if you could harness that energy and make it work for you. That is where the SILA Concepts Turbo Blanket comes in.
Once installed this turbo blanket will better contain the heat from the turbo manifold and away from other engine components. This has two benefits. First, by keeping that heat off other components you will increase their longevity. Second, by better containing that heat more thermal energy gets directed toward the turbine. Because hot gas fills more volume than cold gas this increase in thermal energy actually translate into a faster turbo spool!
More information can be found on our website
Titanium
https://madnessautoworks.com/2017-J...mal-blanket-by-sila-concepts-titanium-pid4611
Red
https://madnessautoworks.com/2017-J...s-red-silicone-fiberglass-outer-shell-pid4612
Black
https://madnessautoworks.com/2017-J...la-concepts-black-silicone-fiberglass-pid4613
Let us know if you have any questions
vBToucan.com Vendor
Discussion Starter #2
Looking for the best value for your dollar to upgrade your Jeep Renegade? The SILA Concepts Turbo Blanket is one of the most cost-effective upgrades on the market!
Heat is energy so make that heat work for you rather than against. By installing one of these Turbo Blankets into your Renegade you will keep more of the heat generated by the exhaust gases directed toward the turbine reducing spool time. By containing that heat in the manifold piping you will also reduce temps throughout the engine bay which will result in a cooler intake charge. That means more oxygen for the motor and an improved combustion.
This is a great mod on its own and even better with other mods done to the car.
More information and pricing can be found on our website
Titanium
Red
Black
vBToucan.com Vendor
Discussion Starter #3
The Jeep Renegade tends to have a bit of an overheating problem being reported by owners and the Turbo Blanket from SILA Concepts is one way to cut down on under hood temps!
By shielding the turbo in this blanket you'll keep more heat pointed at the turbine thereby increasing performance but it will also help to reduce the underhood temps by forcing it out the downpipe.
Titanium
Red
Black
1 - 3 of 3 Posts
