Hi all,
I have been researching this like crazy and am about to pull the trigger on a new set of tires for my renny. I would prefer not to have to run spacers right away since most shops around me won't mount tires if you have wheel spacers. And I don't want to do any cutting or anything if I can avoid it. I have winter tires that came with it from the dealer and now that we are getting better weather and closer to Spring, I want to get a more aggressive AT style tire. I have Rage R20 17x8 wheels with a 40mm offset. Which are close to stock size I believe. I am currently running 225/60R17 and have the 1.5" Daystar lift.
The sizes that I am seeing being used:
225/65r17
235/65r17 (from what I know these will require wheels spacers)
235/60r17
What is my best bet for tire size? Are there any others that I can get a beefier look with and not have to worry about rubbing and whatnot? Basically looking for the largest tire I can get without needing spacers or cutting anything.
225/65r17
235/60r17
