1 - 2 of 2 Posts
I have had my rough country lift for a month now and put over 1000 miles, just had the entire lift kit retorqued at the shop and I am still having a metal to metal noise on any small bump in the road. It is loud enough to hear in the cab but it is very difficult to pin point which side the noise comes from. I have verified that the shop properly shaved the struts to fit and every bold is torqued tight. The shop gave up and said the noise is from the metal lift kit and that i should have purchased the plastic lift kit such as the one from tereflex. If this is the case I am more than disappointed with Rough Country and their equipment.
Does anyone have any ideas or solutions? Has anyone else experienced the same problem?
Thanks
Try spraying silicone lube on where it rubs see if that helps. If not you have 2 choices live with it or replace the parts. Good Luck.
1 - 2 of 2 Posts
