Here are some figures I've comes across for ZF Equipped Jeep Renegades:
a 9.84 ratio spread (from bottom to top). First gear has been listed at 4.71 and then steps up incrementally. I believe 9th or the final OD is listed at 0.48:1...
Trailhawk does it one better i suppose. We know about the 20:1 crawl ratio, but I've also just come across its final drive of 4.334:1. Non TH AWD models equipped with the ZF 9 speed will also use the same 4.334:1 axle ratio with the 1.4 and 2.0 engines.
ZF equipped FWD and non TH AWD's using the 2.4 Tigershark will use a 3.734:1 ratio.
Of note is the Range Select setting so you can actually limit how many gears your 9 speed will use. Equally interesting is that the Renegades software system is able to choose from 20+ shift maps based on context. Selection inputs include engine characteristics, acceleration (forward or not), grade, speed, SC and temperature..
It really is quite the complex little unit...
