1 - 15 of 15 Posts
I just bought a used 2016 Trailhawk w/ a MySky sunroof. It has rained a few times since I bought it, and had no issues. We have had a lot of rain recently, and flooding. I drove through some "high" water on my way to work yesterday 3-19-2020. By the time I got off at 5pm my jeep smelled AWFUL of mildew and musty!! I checked all the carpet and roof, but nothing is wet. Drove home with all the windows down. Today, it still smells. No signs of any water leaking. I have no clue what it could be. I read to check my cabin air filter, but haven't got the chance. I turned the circulation air on full blast for a few minutes thinking it might be in the vents maybe from driving through high waters? It still had the "new car smell" when I bought, and now it stinks. I don't want to mask the smell, but need to find a solution.
and enjoy the forum!
Bring it to the experts and let them find out what is wrong.
If your smelling it now it most likely is old damage or something under the hood or in the AC system or ect.
Bring it to the experts and let them find out what is wrong!
Old damage was found as I read the old forum posts last night. Seek and ye shall find, ask and ye will hear......
Old musty smells mean you are either nose blind or not wanting to have your Jeep looked at.
FYI and I hate those letters. Search low on the front of your Jeep behind the wheels. water has been gathering there for many a long time and seeping into your deafening and carpets.
Don't you just love it when someone says I smell mildew for the 1st time. :unsure:(n)(n)(n)
It was believed to be the A/C unit, nope. No filters.
Merely a grommet, low down that allowed an accumulation of water to seep into the "deafening" then a secondary leak was found higher up behind the wheel that was constantly soaked.
The orginal poster of the topic hoped that the dampness was remaining low down until the Garage noted it had spread upwards towards the steering column.
Perhaps I read it all wrong but it was 6 weeks at the Dealership as far as I recall for drying out and replacement of carpeting etc.
I would definitely check the cabin filter. The stink will stick to the A/C condenser and will require a spray type A/C condenser cleaner to get rid of the smell.
Was the rear floors of your Jeep wet with the smell of windshield solvent? My 2016 had a broken line to the rear wiper and the car smelled like solvent. It was a terribly expensive repair. I was told that if it wasnt repaired the car would eventually have a mildew and musty smell. Jeep had to be stripped to the frame and the wiring harness replaced to fix the solvent line.
The previous owner may have done what you have done; drove through high water. They had mold/mildew (causing the musty smell) which eventually dried out so the stink died. You got it re-wet, so now it's "alive", literally, once again. It doesn't take much water to bring the mold/mildew back to life, but after checking your cabin air filter I'd peel back the carpet to see if the smell is coming from under there. I'd also check the A/C drain hose to make sure it's not clogged.
Replace the cabin filter first. Or spray bleach on it.
The previous owner may have done what you have done; drove through high water. I'd peel back the carpet to see if the smell is coming from under there. I'd also check the A/C drain hose to make sure it's not clogged.
You put it more eloquently than I did and it's ony a couple of posts above therefore I shall try again. (y):D
There was a was a post just a few weeks ago where a member told us of a similar issue and that the Garage couldn't find out what was causing the confirmed fault.
6 weeks later they found it was water ingress from 2 grommets behind the wheel arch. 1 was low down and they believed they had sorted it. Then realised that a 2nd grommet was sitting higher up and still allowing wet weather road surface water to ingress the Jeep.
I cannot know if this is the cause with this Jeep but our member did say they had no further issues after the repairs to the grommets and a whole new set of carpets and deafening within the steering area.
cabin filter need to be replaced, did mine last year its easy to do check you tube, it had bunches on leaves in it and i used a portable vacuum to clean, filter was at wal-mart
I have found alot of people have had this problem, even with new Jeep's, and all the filter changes have not helped. I bought my 2017 Renegade new and the heater has always blown a nasty musty smell. I thought it was just "too new" and something had to "burn off" but it has never gotten better! And now the A/C is doing it as well. I'm now ready to throw a ton of money to a dealership that's going to tell me they can't find anything wrong with it.
Welcome to the forum. If you have changed the cabin filter and it didn't help maybe it is the duct work. Perhaps you could spray some lysol or something like that down the vents and let it sit for a while. The cabin filter and the duct work are both common to the heat and a/c. Good luck. Keep us posted.
Thanks! I'll let you know!
Hi Xanadude, the cabin filter is an easy project and should take no more than 20 minutes. 5 minutes if you know what to do.
If I recall there are only 7 screws to remove in and around the glove compartment (3 are below it, under the carpet). Once removed you can see the filter. It's a simple pull out and replace. Then replace the 7 screws. No need for a Dealership for this replacement.
There is a post somewhere on this forum that shows the exact location of the screws. Youtube also has a video. I cannot recall if I posted a picture of the glovebox removed when I was installing a front light bar. That topic is also around somewhere.
Let me see if I can find a link.
Here is a post by MudPie, simply click the red link:
The red link
YouTube video link from this forum
1 - 15 of 15 Posts
