Hi all.
It is not my first fabrication.
But it is my first Renegade mod I've performed.
Next is front skid plate. Iwill be using 3/16 aluminium with reinforcements to use OE locations.
Then the rear diff using 3/16 steel plate and hopefully fuel tank using aluminium plating.
It is a midship skid plate to protect driveline support bearing bracket. I found it to be too exposed to damage during a breakover.
3/16 mild steel plate, attached using OEM studs.
TH plate is a tin can in comparison. >
Cheers...
Cheers...
