1 - 7 of 7 Posts
I bought my Jeep from carmax in August 2019 with 22k miles on it. I was told that the oil was changed recently, and that the vehicle would let me know when it was time for an oil change. Around 26k miles, the engine stalled in a busy intersection (no lights or codes were thrown). After a few seconds, the jeep restarted itself and I was able to safely exit the intersection. I took the vehicle to my local mechanic, and he stated the engine was very low on oil. I assumed that carmax had given me incorrect information about the oil change, so i didn't think much of it and had the mechanic perform an oil change.
Less than a month later, I started having intermittent issues with the radio. Sometimes the backup camera would stay on when I was driving. Other times, the radio would become stuck on a station (whether xm, am, or fm)at whatever volume you were listening to. Even if you turned off the vehicle and opened the doors, the radio would stay on. Restarting the vehicle would not solve the issue. 10-15 minutes later, the issue would correct itself.
No more than a couple weeks later, the jeep stalled in an intersection again. Slightly more than 4k miles had passed since the oil change. In that amount of time, the jeep had burned off close to 3 quarts of oil. The mechanic suggested I contact a jeep dealership and also advised that I google Jeep Renegade oil consumption test, as they had two other clients experiencing the same issue.
After multiple consumption tests, Jeep has stated that the engine does not burn excessive oil. I said that its strange that the owners manual says to not go more than 10k miles between oil changes, and I can barely get to 4k. Of course Jeep tried to pass the blame onto me for not doing the oil changes in time (I guess they want me to ignore the owners manual and just do oil changes every 3500 miles). They were also unable to recreate the radio issues, so they updated the OS for the radio and said that it should solve the issue.
Fast forward to September 1st, 2021. I can barely get 2k miles after an oil change before there is a noticeable loss of power. The vehicle is just outside of the 60k warranty, has thrown the code for cylinder 3 misfire, coils & spark plugs have been replaced (my mechanic kept the old ones to show how bad the issue really is). The engine has a really rough start, especially if it has been sitting for over an hour. After using a boroscope to verify that oil is pooling on top of all the cylinders and performing a leak down test, the mechanics have determined that I need a new engine. Of course, Jeep is denying responsibility since the vehicle is outside of warranty (even though the complaints go back to when the vehicle had less than 30k miles and the vehicle was only a year old).
So now, I have a 3 year old vehicle that needs a new engine. It has died in 7 intersections and at the hetch hetchy reservoir on a 107 degree day. It continues to have intermittent radio issues (the update did reduce the frequency of radio issues). I have to keep a spare 5 quarts of oil in the vehicle at all times just to prevent myself from being stranded. It is a total bummer when you consider that I have 2 toyotas with zero issues (just oil changes, filters, brakes, and regular maintenance) and both have over 200k miles on them ( a 2001 Tundra, and 2015 highlander). In fact, this jeep replaced my 2000 Camry with over 300k miles that was totaled in a hit and run.
It has really left a bad taste in my mouth for modern jeeps. I've only ever had one other jeep (a 79 cj), which was fun but definitely not commuter friendly. I had originally planned to get a gladiator when my tundra finally retires, but I can't bring myself to buy another one. I'm really not sure how this one even passed the oil consumption test. None of the consumption tests seem to show how much oil is being lost. For the record, the only time the oil change light has ever displayed was the time that they forgot to reset it. I've never even gotten close to having it go off on it's own.
that just shows you that a dealer is the only place to buy a car---i have heard more horror stories buying a car on line and towed to your house. what do they give you seven days and then it is your problem
I got all my work done at a Jeep dealer. I kept on complaining and kept a very good record of how much oil it was using - 1000 to 1200 miles would always result in a quart low. If the rig was in warranty it was probably not a great idea to have others work on it but that shouldn't void your warranty; they will make you prove the oil was changed at the specified intervals (I do 5000 miles) and likely receipts would be necessary and the type/viscosity of oil will have to be noted. They specify a particular type and viscosity of oil and going outside of their specs could be said to possibly cause engine damage. The oil consumption test is done at a dealer. They change it, then have you bring it back in about 1400-1700 miles, then they check it. Has to be their oil (Pennz synthetic) so they have control over how the engine was maintained. Even then they tried a couple of times to tell me it was normal. Fortunately I have a fair amount of experience as a mechanic and could argue the service adviser into a corner about that. I got a new engine a few months back and it has run great ever since. At 3000 since the last oil change not a drop used. I think it will be just fine.
I would contact Jeep Customer Service and stick with it until you get a replacement. They are kind of reluctant to replace engines but they will once there is no other possible way of making things right. It really sounds like someone dumped theirs and whoever sold it to you got stuck with it. Stalling in the middle of the street was one of the things noted when people had this problem. No car should run out of oil to the point where it stalls between oil changes. Yeah you're supposed to check it but it still isn't supposed to use that much.
I haven't read all the way through. I stopped at Jeep is denying responsibility. I had a case open with Jeep at first and got a warranty up to 90,000 thankfully. But when the oil consumption test showed I was losing oil and they agreed to replace the long block, it was given back to me on a Monday and that Thursday it ran out of gas, even though it showed I still had 2 bars and 46 RTE. At that point I called 1800lemonlaw. I don't know if there's rules for the group not to give names like that. If so I'm sorry for that. It's just what I did and part of my story Please call them if you still have the issue. Again I didn't keep reading yet so if this has been resolved I'm sorry. You don't pay unless they reach a settlement and then fca pays their legal fees. I had the same problem but luckily within warranty. The long block engine has been replaced and I'm afraid there's still an engine problem because like yours, there's a very rough shaking when I start it and when I turn it off. When it's idling at stop light it shakes. When I let my foot off the break right before I go to give gas the rpm needle bounces up and down. One mechanic suggested having cylinder compression test done after he started it and heard and felt good rough. I'm at the point of having to decide between cash settlement and repurchase. I'm afraid of being without a car so don't know if I should agree with repurchase. I'm afraid to keep the car if there's still an engine problem. I came on tonight to see if anyone had their long block engine replaced AND still had engine problems and needed it replaced again.
Now I’m worried about mine being replaced😳 I’ve also got a case going with the same lawyers.
1 - 7 of 7 Posts
