Well, that was almost-certainly because your battery is/was old, as discussed in the other thread.Check the uconnect screen. ... Make sure there are no lines in the screen.
Had the battery tested and it passed with flying colors. Not running 12.8 volts. Cranking 10.9 volts. Running 14.3 volts. Bring to dealer to test the screen. I contacted Mopar about my extended warranty (max care) and they said it's covered. What is not covered is delamination of the screen. There is no delamination.Well, that was almost-certainly because your battery is/was old, as discussed in the other thread.
Did you ever replace the battery, by the way?
Which does bring up another thing for Neo1963 to look at -- how old is the battery? With these electronics, if the battery is over about three years old, it's time to seriously think about getting a new one...
That's the old/original battery from 2018?Had the battery tested and it passed with flying colors.
Well, your Mountaineer and especially your TJ are much-earlier vehicles, with far fewer and -sophisticated electronics. Therefor less-sensitive to power-supply issues.It is the original and no have not changed yet. The repair shop I have known for 30 years and they have been in business for 45 years. I trust their opinion but as we all know**** happens. The battery in my 02 TJ is 9 years old and our 2010 mountaineer battery is 7 years old. Go figure. I do appreciate your opinion very much. I need to make a decision by Tuesday because the dealership appointment is Wednesday a 8:30 am.🤔
OK, I don't know much technically about batteries (except that you have to do a load testThe shop did do a load test. Half of the cca. I believe the battery has a 600 cca rating. It held 375 for 10 to 15 seconds.
The $140 would be for one-hours' labor to plug in and do a scan. Pretty standard, I'm afraid...I made an appointment at the dealership close to me (Northport) to check out the screen. Cost 140.00.
No idea. Like I said, I'm not a battery techie.Just curious what would you consider to be passing numbers on the battery
I'm reall glad to hear that.The result was the screen was bad. ... Fully covered under my Mopar max care warranty.
Thank you Marek for all your input it is much appreciated 👍I'm reall glad to hear that.
And I'm honestly surprised your four-year-old battery tested good. But these things really vary. Keep an eye on it, though...
