1 - 20 of 74 Posts
Bought a BRAND NEW Renegade North 4X4 Last Friday, drove 190 miles home so now total 256 miles on it as it had been out for a few "test drives" as I was told at the Dealership, the next day being Saturday I went to go to the store for Milk and there is NO 4 WD, the 4WD light won't come on nor will the selector move to "snow"(we have a foot of the fresh stuff), it just stays in "Auto" with only FWD and gets stuck, and now it is showing errors on the dash as follows:
* Dynamic Steering Torque Service Req'd
* Service ESC System
* Service Hill Start System
What gives here ?
Is this a common problem with Renegades ?
Has anyone else here experienced this problem with their BRAND NEW Renegade and if so what was the fix ?
Going back to the Dealership Tuesday morning, but we need a RELIABLE 4WD where I live here in Canada, hence why we bought it ?
I will keep this thread updated as the repair process on the Renegade moves forward at the dealership, and the final "Fix", because from my research here and around the internet, this seems to be a somewhat common problem ?
* NO 4WD,
* Dynamic Trq Service Req'd,
* Service ESC,
with the "Traction Control Off" Icon appearing on the instrument cluster and it's T.C. button unresponsive
Although,
from the other reports I could find no feedback of what the definitive "Fix" was ?
It's never fun to have a problem with a Brand New Vehicle ?
that said,
I have to say that even for the brief 200 miles we drove the little Renegade home from the dealership in a Canadian Winter storm dumping 12" of snow, through the Rocky Mountain passes where we live, to say that we were IMPRESSED with the way it hugged the road and dealt with the horrible road conditions would be an UNDERSTATEMENT !
The little Renegade was fantastic in "Snow" mode, never getting stuck, never sliding around, and it was unbelievably stable delivering a much appreciated confidence in such conditions.
I think FCA have a winner here folks ?
There's no difinitive fix because the errors are largely generic. There are lots of fixes to a number of problems that cause said error warnings.
You seem to have a steering error and hill start error, which are novel, but the ESC and AWD error are not.
-Pretty much ANY kind of issue with transmission data, either an error or unparsable garbage data, will cause the system to disable AWD.
-Any kind of issue with ABS sensors will cause the AWD to disable as well as ESC and traction control, because it can now no longer monitor (or decided it is getting bad data it can't trust) wheel spin. Which is needed for TC, ESC, ABS, and AWD to function properly.
-Anything that causes can-bus data to get corrupted or puts garbage on the can-bus. Which has been any of the following: crushed wiring harness causing a short, bad PCM, firmware bug for transmission, bad grounding, etc. This however tends to create more errors.
There's also the very unfortunate souls who get the electric gremlin and have a bunch of errors and bunch of bad symptoms and nobody seems to be able to fix it. They are in the minority though.
Your errors mostly have a theme everything on your list, TC disable, ESC error, AWD error and dynamic sterring torque service required (DST is part of ESC to control driver input making skid problems worse) are all ESC related. The only one not obviously interconnected is hill start, but mainly because I don't know exactly how jeep implements theirs. If they use wheel spin as part of the calculation, then it's bundles with all your other errors.
I'd say #1 odds are wheel spin sensor(s) having an issue. However, that would suggest you shoudl also be getting an ABS error of some sort.
#2 is I would say vehicle angle sensor. If they use something like a 6 axis sensor, you need that working to determine incline angle (hill start and TC), as well as vehicle yaw (ESC needs this as does DST), AWD punts easily, I suspect lack of vehicle inclination info would cause it to punt. ABS might need that ingo, but for what ABS needs to do, it can get around needing vehicle position and compute almost all it's info from differential wheel spin.
OK, so we took Renny back to the local Dealership, 3 hrs later it's "good to go".
So the story goes....
seems it had sat at the dealership a little too long before we purchased it ? and somehow it got missed and required 5 Computer software updates. The Dealer supplied us a sheet showing each of the 5 "old" software versions, and the corresponding 5 "new" software communication versions for each that they downloaded and installed for the ESC, Hill Start, Dynamic Steering Torque, BCM and TC control modules ?
I will admit to being a bit of a Techno-tard here.... nonetheless, about 3 hrs later(same day) we picked up Reny and everything seems in good working order.
Still LOTS of compact snow/ice on our Highways, I am pretty darn impressed with the Renny's stability, and even better handling on our side roads with plus 1 ft of snow/ruts/drifts.
I am keeping my fingers crossed that the "updates" were the problem and now fixed for good, because if it is ? This little Renny is a Canadian Winter WINNER in my books !
My Jeep Renegade is displaying these EXACT error codes on my display....(Dynamic Steering Service Reg, Service ESC System, Service Hill Start System). I have no 4WD, traction control button not functioning and my steering feels sloppy. I'm so glad I saw this post, I just signed up to find out what the heck is going on with my Jeep?!! I have a 2015 Renegade Trailhawk and have never had any of these problems until now. I will be taking the jeep in tomorrow to the dealership.
Was the software upgrade the only thing that was required? May I ask what Jeep dealership you went to so they can call them if they have any issues? I will show the mechanics this post also so they don't try to stiff me with any miscellenous non-sense.
Thank you again!! =)
What gives here ?
so its been about a month and a half, any new problems or is everything still good?
I had similar issues on a road trip in May of this year. I have a 2016 75th Anniversary Edition with the 1.4L turbo engine and manual 6-speed transmission. Mileage at the time was about 10,500. During the trip, we drove hundreds of miles in light-to-heavy rain and on the fourth day of the trip I got the following error codes, along with the related idiot lights and a complete lack of power steering assist:
The power steering system ceased to function but I have no way of knowing whether the ESC system disabled itself. I was on the NJ turnpike with no good location to pull over, so I drove to my destination. After about 45 minutes of key-off standing, I re-started the vehicle. The warning lights were cleared and all vehicle functions returned to normal. The symptoms did not occur again on the remainder of the trip.
On my return home I took the Renegade to the dealer for service of these problems as well as a cruise control that would frequently stop working and not resume functioning untl a key-off restart. Unfortunately, the dealer found no error codes for any of the problems (power steering, ESC and cruise control), they could not replicate the problems, they found no necessary software updates and basically said that there was nothing further they could do.
None of this was very satisfying and I'm left without any effective remedy or recourse. This is not encouraging or reassuring and in the back of my mind I have a nagging feeling that days of driving in very wet conditions may have had some influence on the problems.
Not good. No error codes means that the dealer just more or less gives up Which is not acceptable.
I would check all ECU connectors and battery leads and straps I could get at for water ingress.
Guess I'm not the only one
My 2016 Trailhawk is also giving the Service Hill Start, ESC System, & Dynamic Steering Torque errors. No 4WD. This was after I went through mud in the lane that goes through the hay field. A little disappointed if a Jeep can't handle that. Kinda worried about the coming winter.
I've only had it 2 months. Hope this isn't a sign of things to come.
Hi Rene,
I understand why this would be concerning. Let us know via private message if you decide to have your dealer look into this so we be of some assistance to you while your Jeep is at the dealer.
Lydia
Jeep Social Care Specialist
We've been having something like this. It also includes e-brake, ABS, and power steering. It first happened to me once and never happened again and then a few days ago it happened to my wife like 4 times in a row and it actually shut the car off even while moving.
It happened to me today twice again.
I've read on another thread that it could be caused by a poorly seated connection and browsing through the Repair Manual I figured out that all those services end up in the Body Control Module and that perhaps the bad seating is somewhere in those wiring harnesses.
Anyone knows about this? I'm starting to think about pushing the Renny off a cliff.
I understand why this would be concerning, Carlos Espinoza. Let us know if you make an appointment with your dealer. We would be happy to have this concern documented for further handling while your Jeep is at the dealer.
Lydia
I made a thread because I think I fixed it. We took it to the dealer (we're in Colombia) and they said that it was due some water in the engine compartment fuse box. It happened again on the way home. I opened the dash fuse box and pressed the top left cable in and it clicked in a little bit further and it hasn't happened again. Will keep you posted.
Nevermind
It JUST happened again. Taking it to dealer.
Keep you posted.
1 - 20 of 74 Posts
