I was going to replace my rear brake pads and saw that there is an EPB maintenance mode on all the write ups that is accessed via the dash settings. Well...of course I don't have that under my settings.
Is there a manual way to put the Jeep into maintenance mode or would simply not having the parking brake on be sufficient?
(2016 Trailhawk/U.S)
Aha! you have fallen foul to that dreaded scenario also.
A few years ago I asked on this specific forum for an answer. Many were of a varied response but ultimately, yes, rear brakes pads can be changed but it requires the Jeep to be linked to a (for want of phrase) a computer. It confuses me, OBD, alpha OBD etc hence I called it a computer.
The brake pistons require to be retracted and then actuated again upon removing and installing new pads. Unlike the front pads that are basically a DIY job for £20.
May I ask if your rear pads really need changed?
Removal of my front pads yesterday after 55k miles thereabouts still have around 75% of the original pads.
If I am not mistaken, rear pads should not under normal circumstances need replaced before the front ones. In my case the Jeep has already passed an MOT and no mention of the pads being worn were intimated.
Just reconsider if you really want to replace the pads if the low level pad wear indicator has not yet illuminated on your dash board.
