Does that mean the FWC no longer works after fording or that it simply needs time to dry out before working again?Hi,
It seems only Trailhawk version has water fording capability, this is due FWC sensor placed in the front bumper and not water sealed?
It would seem even a major rain storm or getting doused by a passing 18 wheeler could have nearly the same effect as fording.
Has Jeep published any text on the fording issue or the need to keep the FWC sensor dry? If so, can you provide a link or paste in the text?
In theory this problem doesn't exist because TH isn't equipped with FWC and fording with any other version (even 4WD) is at your risk because is reported without fording capability.Does that mean the FWC no longer works after fording or that it simply needs time to dry out before working again?
Thank you for this sheet, on the italian version is reported has "N/A"The 4X2 can't water forge but the standard 4X4 can up to 12" and the Trailhawk 19". https://www.jeep.com/assets/pdf/renegade_spec.pdf
