My TH idle is slightly noisier than I'd expect, but then again, this is the first 4 cylinder I've owned in about 13 years. I checked the oil just to make sure, and it was full. I've gotten used to the noise now and it certainly doesn't drive like it's having any issues. Most new cars utilize a larger plastic cover with rubber isolators to help cut down on engine noise. The Renegade is lacking this as well.
As far as the MPG, there could be many factors attributing to your number. Bad fuel, tire pressure, how much you use the A/C, how you accelerate, etc. Not to mention, the computer figure could be inaccurate. Your best bet is to fill it up, reset your mileage trip counter, and run the fuel down to E. Then old school it and divide the miles driven by the fuel tank size for the most accurate number.
