On the 2.4 engine, there are two bolts holding the starter. The top bolt is removed from the transmission side, and the bottom bolt from the engine side. Both bolts are different sizes, so don't mix them up. I found it necessary to remove the right axle shaft, to get the starter out. It isn't a pleasant job, but it can be done at home. Best of luck to you...Mike
