DodgeBoy that was an excellent link. I found it a very interesting read.
Hello All,Has anyone noted any engine oil consumption in their Renegade 2.4 engine?
When my car was delivered it had 190 miles, part of that was because my local dealer didn't have the color we wanted so they picked it up from another dealer. Anyway the oil level was about 1/2 between full and add marks. Maybe the engine wasn't filled at the factory? I added enough oil to bring it to the full mark.
The car now has 2800 miles, I have checked the oil several times since it was filled, yesterday I noticed it was about 1/3 down from the fill mark.
I realize that isn't a big problem but I haven't experienced that much oil use on my last several new vehicles. I also realize the oil consumption may decrease after break-in.
That said, I know most new cars now require very little or no break-in miles.
Clifton
I was also told to do this test. The dealership says the manufacturer states that the renegade is supposed to consume 1 quart of oil per 1000. Miles. This is not true. I had them perform the test twice. They checked my oil levels at 1500 miles use and they determined that it was a defective engine. I have the 2.4L. 2018 Renegade. I am now waiting on my new engine. Be sure they do these tests before your power train warranty runs out. My new engine will be no cost but I had to push the issue for two years. A little knowledge about your vehicle is a must to get them to do the right thing. You won’t see major oil consumption until around 30-40,000 miles. It gets worse. Have them replace it if possible.My dealership wants to do an oil consumption test? At 6400km, took it to the dealership because hubby checked the oil and it was super low. Dealership took a look at it and suggested that I get an "oil consumption test". They topped up the oil and ask that I bring it back to them after 1000km.
Is this a situation that others have had done?
My 2018 Ren burned all but .5 quarts before it hit 3000 miles. I am now at 62,000-ish miles and it continues to burn nearly all the oil. Chrysler refuses to perform tests requested. I hope you continue to see less and less oil used!I should hope not.
I checked mine looked to be about a quart and half low dealer ship told me that is in normal spec when I asked for that in writing they refused and told me to go buy and add it if I think it is low and that if the engine is damaged because of low oil that would be my fault and not covered under warranty. 6000 miles eats a quart and half of oil at $10 a quart is "normal"? I so can not wait for my lemon law case to be finished.This may turn me away from all Jeep/Fiat products if there customer care is this bad. They even told me I checked it the wrong way so I found on the disc how to check it properly it is still low.
Checking Oil Level
To assure proper engine lubrication, the engine oil must be maintained at the correct level. Check the oil level at regular intervals, such as every fuel stop. The best time to check the engine oil level is approximately five minutes after a fully warmed engine is shut off. Do not check oil level before starting the engine after it has sat overnight. Checking engine oil level when the engine is cold will give you an incorrect reading.
Checking the oil while the vehicle is on level ground, and approximately five minutes after a fully warmed engine is shut off, will improve the accuracy of the oil level readings. Maintain the oil level between the range markings on the dipstick. The safe range is indicated by a crosshatch zone. Adding 1 quart (0.9 Liters) of oil when the reading is at the low end of the indicated range will result in the oil level at the full end of the indicator range.
