I went to change the spark plugs on my daughters renegade. Cylinders 2 and 3 had oil in the spark plug well. Maybe only an ounce or two. Cleaned out the wells, replaced the plugs and tube seals as well as the valve cover and oil separator o-ring. 2000 miles later (today), I checked the spark plug wells and found more oil in 2 and 3 spark plug wells. Has anyone come across this issue before? My thoughts are a bad PCV valve or the tube leaking at the cylinder head side, where it threads in.
I made a tool to remove the tube but since I have never done this before, I'm kind of hesitant to start there. I may just try the PCV valve first and see what happens.
