1 - 15 of 15 Posts
Jeep Renegade 4x4 Limited 2015 - CRD 2.0 Diesel
Hello,
I have bought a Foxwell NT530 diagnostic tool.
I managed to reset the Oil Counter reset (days and KM) this worked fine within the Instrument Dashboard Cluster
OIL CHANGE MESSAGE and LIGHT still popping up when engine is running.
HOW CAN I RESET THIS? btw, the 3x pedal push trick does NOT work.
I have a manual gearbox, so putting in Park is no option with the manual reset procedure...
Has anyone the NT530 Foxwell procedure?
Kind regards and thank you
I had it fixed by the garage with the professional machine and have no issues. Maybe you need to do the same.
Is it possible your machine tells you what the fault is but doesn't correct the error code to a full reset?
Jeep Renegade oil change light after an oil change service, please follow these instructions: 1. Turn the ignition to run (one position before starting engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition off and then start the engine to verify the indicator has been reset.
The OP states the pedal reset isn't working which may be a thing on non US models. I know it does not work on mine which is a RHD export model. I have not tried a scan tool yet though.
I also noticed that I cannot put my brakes in service mode from the apps screen either which may also be not available outside the US
After several times, still does not work dear Jeff1
Its possible that on EU cars the pedal reset does not work, any people who have EU car?
Kind regards
Discussion Starter · #8 ·
Hello, Still not be able to reset the upcoming message to change the oil, it only pops up when engine is running and does not save into the messages if the engine is not running.
So, Has to come from the engine ECU,
think the pedal trick only works if the message is kept in the dashboard memory
Anyone any experience to fix this without going to the deaker??
Regards :cool:
Do not visit a Dealership and get ripped off at £70 per hour labour for a 5 minute job.
Any local garage with the machine that reads the ECUs of a variety of vehicles will likely connect up your Jeep, reset it and likely tell you to supply the cakes. Bung them £10 and they are quite happy as they surmise there could be a possibility of you returning to them for other work needing carried out.
Discussion Starter · #10 ·
Hi, I bought a Foxwell NT520, according to Foxwell I should be able for all oil service items to reset with this tool but i did not succeeded in this, only the days and km counter is reset.
Would be great that i could find someone with the same tool ans car.
According to Foxwell it should wor, but they do not have a manual.
Regards,
Glenn
Glenn this is what happens when we tinker with the Jeep and don't fully understand its inner workings.
Get it to a garage.
Discussion Starter · #12 ·
Get it to a garage.
hahaha, this is a good one
I await the Foxwell procedure first of all. About understanding the Jeep's system, probably there is no one here who does hahaha
regards, Glenn
Regards,
Glenn
maybe the good old fix it all, disconnect the battery for ten minutes plus and see what happens, then try the reset option if needed, THEN bring it to a garage, you probably screwed up the ecu
Discussion Starter · #14 ·
There is nothing mentioned that with the pedal procedure one can screw up the ucu...
not talking pedal push, talking about tool you plugged into the port
Foxwell NT520 Updated to NT530 Scanner with 1 Free Car Brand Software+OBD with NT510 NT520 Firmware Updated Version
Notice: The NT530 usually comes with no car specific software as default, customer can download one software for free from foxwelltech.com, (The update tool only compatible with Windows OS currently.)
is your scanner up to date--- just throwing out ideas
1 - 15 of 15 Posts
