21 - 22 of 22 Posts
Warranty job then? Mine's 3 years old and works fine.
Hi there. Could you please kindly advise on how to clean the contact loom in the door? Do I need to disconnect the battery before spraying both contacts in order to avoid shorts?
I've never disconnected the battery, but you can.
Disengage the loom connector and check both sides of the connector and gently remove any dirt or corrosion with contact cleaner.
21 - 22 of 22 Posts
