Nice to meet everyone. My main issue is that for about a year now, my fob works on and off. I have to lock it manual and use the key in the fob to manual unlock the vehicle. It doesn't do it's remote features anymore and I have to depress the start button with the fob for it to start. I have replaced the battery multiple times and it never fixed it.
Another issue I'm having is when I went to Valvoline for a quick oil change, they recommended a lot of fluid exchanges which I did not get. According to our manual, the ATF should be good for the life of the vehicle but I've read in here that some do change it. The next is the Front Differential and Rear Differential fluid. I only see RDM fluid to be inspected but never to be replaced. And there are specific oil suggestions to use to replace "if equipped". The front differential is what i would assume the PTU fluid and it says the same. There's no mandatory or recommended exchanges. But for some reason a lot of people in this forum has replaced them otherwise. Can someone explain? Thank you in advance.
