1 - 17 of 17 Posts
Nice! They sell black overlays for all of them parts too.
Reactions: Jamie Smith
Okay.....what exactly did you dip ? The grill trim rings ? The badges ? I can't see what was changed.
Looks great! I’m not a big fan of chrome myself and will be doing the same in the future.
I really want the jeep logo on the hood replaced as the little details on the lettering are not perfect. Luckily it’s plastidip and peals right off.
I completely removed the Jeep logo from the hood. Looks way better in my opinion.
I did
2396350457
the overlay rings. 20 bucks on Amazon and easy application. They are glossy though so I might remove and paint Matte black.
Yesterday I plasti dipped my rims. I love the new look. Here is a photo journey of the change.
2396350458
No color
2396350459
First coat
2396350460
Second coat
2396350461
Fourth coat
2396350462
Sixth coat
2396350463
Done
Some things I learned, if anyone cares. First, if you have fairly complex wheels like these, definitely better to remove them. Either you will miss many areas until you rotate them or you will have over spray issues trying to turn the can. Second, shake the can often while spraying to prevent spluttering. Third, it is totally worth doing but now that I am sure I love the black, I will paint them for a more durable finish until I can afford new.
So help me out.... does the platidip stay durable on the wheels or does it weather and peel eventually? Also how many cans did it take for the 4 wheels?
what if you get a car wash or scrub with a brush?
It’ll stay quite awhile. Eventually you’ll need touch it up again though.
I “dipped” my front GMC emblem and a small piece of molding on my Yukon and it took 3 cans. I believe the instructions call for 4-5 coats. If I remember correctly, I did 5.
I’ve pressure washed it a few times now and it’s held in place perfectly.
You only need 1 can per wheel. It is not meant to be a permanent solution. It is definitely only going to last well for about a year. I did it to test and be sure that I would like my wheels in flat black. If you want a more durable and permanent solution then something like Krylon Automotive Enamel spray paint would be better.
1 - 17 of 17 Posts
