First of all, I like my Renegade a lot. With studded winter tires the grip and traction is incredible. I have never driven anything that can compare. The comfort is also very good. And it's a fun car to drive.
Now over to the not so good. Jeep must have done a really bad job testing the car in cold climate. When the outside temperature went down to around -15 °C (5 °F) and lower, the car started to show all kinds of fault/alerts like Serv 4WD, Check parking or electronic brake, Stop/start unavailable and Check Engine. In addition, after driving for 40 minutes at moderate speeds and then leaving the car for 24 hours in -25 °C (-13 °F) , the battery didn’t have enough charge to start the car. I checked the battery and it is only 72 Ah which in my opinion is insufficient for climates where the temperature can get down to -30 °C. After a night of charging the battery and a couple of hours with the block heater on, the car started. When the outside temperature went up warmer than -15 °C (5 °F), the messages disappeared. When Check Engine is showing, the car is only front wheel drive.
The most stupid or laughable effect of these faults was the following: The car said Stop/start unavailable and the system could not be turned on with the button. When I came to work I drove slowly into my parking space and braked the car to a stop half way into the space. Then the car decided to activate the stop/start system and automatically stopped the engine. The problem was that the system was apparently still unavailable so when I released the brake pedal the car wouldn’t start automatically. I had to switch off the ignition and then on again to start the car and drive it the last meter into the parking space.
I really hope that Jeep has software-updates to fix these issues, but I fear that these low temperature problems are unknown to Jeep and that my car will not be fixed this winter…
Anyone else experiencing problems in cold temperatures?
