1 - 4 of 4 Posts
Jeep Renegade My18 (2018) 4x2 1.6 Mjt 120 HP
Hi all, i'm Italian so sorry for my poor English
I want install "puddle ligts", the ones under door
Actually i have a battery model attached to the door
Motor vehicle Automotive lighting Automotive tire Hood Automotive tail & brake light
I want substitute them with a fixed one like this
Audio equipment Gadget Cable Electronic device Wire
But i want timing them on and off with tha seme timing of dome lamp.
I found an Electrical scheme of dome lamp
Rectangle Font Parallel Diagram Drawing
Pin 2 (black) is ground
Pin 5 (violet) +12 v
Pin 6 (yellow/greep) +8v, its give current to central led of dome lamp
Pin 4 (yellow) it's give a dimmed current on dome lamp ligth under button
Pin 3 there is current only when door is open.
There is someone wich can confirm that inside the dome lamp there is a Relay on command of pin 3 ?
Someone have mounted puddle ligth with time sincronized with opening door mechanism ?
sorry if I was verbose
hey nice addition! don't worry about your English! (actually your English is just fine) English may have 1,000,000 words but that helps make it easy to use any of the many words that have the same or similar meaning. Where did you find these puddle lights?
Looks cool! Some one will chime in to help you soon.
1 - 4 of 4 Posts
