1 - 14 of 14 Posts
I never had a car with with windshield washer on the back, so i am not used to turn it on. But the other day I was trying to use it and no liquid is coming out. I had just refilled the tank with fluid so i thought it could be that it has a separated container. IDK what to do, i guess i should take it to the dealer. I hear the noise from the mechanism working tho, it just that liquid is not coming out
Same reservoir for front and back, so if the tubing is hooked up properly , motor is working and you have fluid then it should spray. Might check bottom of reservoir bottle to ensure tubing is not loose. Let us know what you find out.
Hi there, I got it working already. A friend told me that it probably was air in the system since it was not used before and to keep trying and trying. So I filled out the reservoir again and started pressing back and forth to wash both windshields. After a little while it started working, I am so happy it started working!!
I noticed that if I don't use my rear washer for a long time, I have to hold the wash button for quite a while before the liquid starts squirting. I figure that the liquid very slowly drains back into the reservoir if you don't use it regularly leaving the plastic tube empty for part of its run.
It sprays nearly right away when I use the washer a lot.
Reactions: FirstJeep23
I've been having the same issue, but with my fronts, sometimes it works, sometimes it just spits out. Not a cold issue but it is willy nilly on when it works and doesn't work....smh....anyone else experiencing the front issue?
So it "spits" instead of providing a nice washer stream? Check to make sure your reservoir is full. Otherwise maybe there is something blocking the nozzle or one of the washer-lines has come disconnected or is damaged.
My fronts always work right away, but I do use them at least once a week.
That is hilarious! Perfect for those tailgaters. ;)
Has anyone replaced the rear blade, also is there a way to adjust the spray pattern to actually spray in the area of the wiper path? Mine does not spray a useful pattern or direction at all.
The rear also acts up in cold/freezing weather. ❄🥶
I must have a rear washer tube disconnected from the tank bc when I hold down the rear spray button I have washer fluid leaking from the drivers firewall area.
1 - 14 of 14 Posts
