Do you guys already have in mind what colors you're going to have available?We are going to make tow hooks for the Renagade that does not have them and can be any color.
I can't help but wonder if you can put a second tow hook in the rear bumper. I wonder what's behind that space on the right side of the rear bumper. Also have been wondering if 4 tow hooks could be added front and rear bumpers of non-Trailhawk models.We are going to make tow hooks for the Renagade that does not have them and can be any color.
I'm curious about this as well. What is involved in adding tow hooks to a Sport or Latitude model? Do the front and rear bumpers just have some pop out caps that you take out and then you can just screw them in, or do you have to start cutting and drilling things?We are going to make tow hooks for the Renagade that does not have them and can be any color.
This is a detail-picture of my Limited.I'm curious about this as well. What is involved in adding tow hooks to a Sport or Latitude model? Do the front and rear bumpers just have some pop out caps that you take out and then you can just screw them in, or do you have to start cutting and drilling things?
They will be red in color. here is a pic of the rock guards (splash guards) we have now. We can make any type of combination of tow hooks you want. the one shown screws into the stock opening, but we will make the heavy use ones that bolts to the frame.We are going to make tow hooks for the Renagade that does not have them and can be any color.
The right rear spot is a cap, underneath which is the socket for the screw in tow hook. Probably could mod it fairly easily since it's already strengthened there for towing the vehicle onto a flatbed truck.I can't help but wonder if you can put a second tow hook in the rear bumper. I wonder what's behind that space on the right side of the rear bumper. Also have been wondering if 4 tow hooks could be added front and rear bumpers of non-Trailhawk models.
Yes we make hooks and receivers for the Z/28 Camaro for track use, we can make heavy duty front and rear hooks and receivers for the Renegade.The right rear spot is a cap, underneath which is the socket for the screw in tow hook. Probably could mod it fairly easily since it's already strengthened there for towing the vehicle onto a flatbed truck.
I checked and we can add tow hook front receivers under the two phony vents that are removable rear can be done alsoThis is a detail-picture of my Limited.
Behind this bumper on the drivers side is the Radar located, no hook possible to mount.
Here you can see, that there is some plastic to be removed at the Position of the hook. But the hook has to be longer than the original of the trail hawk Version, because the bumpers shape is different.
