1 - 5 of 5 Posts
I will be replacing my spark plugs in a little while so I went to check a few things out. I tried to remove the connectors off the coil packs but they seem solidly attached. I slid the tab back to unlock the connector but they won't budge. Should I spray them with WD40 or some other product to see if that helps? Any suggestions are appreciated. Thanks.
Discussion Starter #3
Thanks for the reply Mrsig. I was sliding back the clip and pressing it down like the 1st video but I think it was just stuck on after almost 5 year. I put on some gloves to get a better grip and that did the trick. Thanks for your help. They were really on there tight, they seemed clean once removed though. Thanks again.
Yep dirt mud all ways gets on the connectors any where on our Jeeps. Try to replace a 12 year old front wheel sensor that the connector is coated with it and try not to break it.... Oh boy!
WD40 won't hurt anything if you chose to use it. In fact it will aid in cleaning the parts as you take them apart.
1 - 5 of 5 Posts
