1 - 8 of 8 Posts
My black TH has some very minor scratches caused from going through some tight trails. You cannot feel them with your finger so they are only clear coat deep. Anybody have a good way of removing these without using a buffer? All the products I see seem to be more geared towards deeper scratches.
I have had great results with Meguire's Scratch X. It will not damage your paint and does a really good job on fine scratches, swirls, etc..
From the manufacturer..
Effectively remove fine scratches and swirls from your paint by hand!
Meguiars SCRATCH X 2.0 is the must-have scratch remover for isolated paint blemishes! Only Meguiars SCRATCH X works by hand on all types of paint and all types of scratches. Micro abrasives remove scratches, rather than hiding them. Meguiars SCRATCH X 2.0 is a permanent solution to isolated paint scratches!
SCRATCH X 2.0
does more than just fill in and mask the problem; it’s a powerful polish that actually buffs the offending blemish away--without causing harm to your paint. Now, common sense will tell you that if a scratch is especially deep, or the paint has been chipped you need more than a polish. If you’re faced with such a daunting imperfection, seek the advice of a professional. Chances are you will require a machine applied pro-formula, and unless you’ve acquired some expertise with these items, you’re best leaving it to a professional. However, if what you are experiencing is a ‘surface’ blemish--SCRATCH X 2.0 will do the trick.
SCRATCH X 2.0 removes oxidation, blemishes, light stains, and surface contaminants. Perfect for a specific trouble area, or on the entire car. The strong yet gentle formula is safe for all paints and, unlike some surface correctors, SCRATCH X 2.0 will not abrade your paint--leaving more scratches than you began with. This formula is easy to use, and although it is widely acknowledged by collectors and enthusiasts as a “must have” product, even a novice detailer can use it with confidence.
Use SCRATCH X 2.0 and buff the damaged area, allow to dry, and wipe off the film to reveal a deep, polished shine. If applying SCRATCHX 2.0 to your entire car, remember to work one section at a time. Now that you’ve found the solution--apply it!
I've had good luck with Meguiar's Ultimate Compound.
It's possible to polish out clear coat scratches with just a pad but your arm is gonna be pretty dead afterwards. It's worth investing in an orbital buffer to save time and effort.
I agree, Ultimate compound is good stuff also. I actually use it before scratch X and many times it does the job. Only use the Scratch X if Ultimate doesn't quite get the imperfections out.
1 - 8 of 8 Posts
