From examining two Jeep Renegades. Both revealed quality problems with the chassis plugs, seam sealer, and corrosion control/sound mitigation coating.
Really disappointing that these units are passing quality control over in Italy.
For those who buy one, should consider additional corrosion protection and pre-delivery inspection!!!
On both cars, plugs were added after the fact, and some seam sealer primer was sloppily brushed around to "hold them in". Cracks in the primer indicate the plug moved, and moisture will accumulate in there and facilitate corrosion.
On one car, a plug had been cut out of the corrosion protection and a new plug of different dimensions was added with no seam sealer.
On the other car, the plug was missing completely, the paint was damaged, and the corrosion protection did not continue to that area as it should.
