The camera is an option when buying.The European version dont have a camera. Just the digital image of the car, pops up when u put i in reverse. There are already made room for a camera in the back. But there is just a hatch over the hole. I too would to like to add a camera.
I have it but seldom use it.turkey to be specific. the camera is not even an option... yet.
Just listen carefully when backing up. Or use the Force.turkey to be specific. the camera is not even an option... yet.
So will the Force always be with you Padavant ...... Or use the Force.
or use the lightsaber if it all fails? provided that it is installed in your version of RenegadesSo will the Force always be with you Padavant ...>
this is a good question. i also wonder if there is already a harness installed (small possibility)What insurance company covers the force? I have the beeping thing. but i would like the camera. is it pre wired? ore do u need the wire as well?
If you remove the interior trim from the hatch you should be able to see if the harness is present. My guess is no. Copper wires are expensive and the manufacturer does not incur any extra time/labor penalty for not installing it. So why would they install the harness by default?this is a good question. i also wonder if there is already a harness installed (small possibility)
Not too much "Force" or you'll crash into the car behind you. He he. Oh, right... the other "Force".So will the Force always be with you Padavant ...>
