Hello from Hawaii… 2016 Renegade burning oil and broken vacuum hose. Temp fix but dealer says need new factory part-looks nothing like the original and cost $200 plus install. Any suggestions? Also had oil in wells when changing spark plugs.
Yes! Anyone have a used part? Thank u for terminology. Dealer can’t tell me part name. Orange tube broke so mechanic shortened-temp fix with zip ties😆 New part is totally different and $200 plus install. Can replace just tubing becuz of factory clamp. Yish! Hawaii is limited access to junk yards/extra parts.What are you looking for suggestions about? Finding a cheaper part? It's difficult to tell what is broken in the photo. That's the turbo wastegate actuator. Is the fitting on it broken? You can probably find a replacement actuator at a parts store or salvage yard.
As for oil in the sparkplug wells... well that's probably a valve cover gasket job. Usually o-rings around the well area, but not sure on Renegade.
Cannot replace tubing only-sorry for typo..Yes! Anyone have a used part? Thank u for terminology. Dealer can’t tell me part name. Orange tube broke so mechanic shortened-temp fix with zip ties😆 New part is totally different and $200 plus install. Can replace just tubing becuz of factory clamp. Yish! Hawaii is limited access to junk yards/extra parts.
