This is a comprehensive list of all the standard and optional safety equipment Jeep will be offering in the BU Renegade. Now this list is likely subject to change based on country...
Dual Note Horn: Renegades horn will sound two different tones at the same time to cut ambient noise more effectively
Enhanced Accident Response: Renegade makes life on emergency personnel easier as it turns on interior lighting flashes hazards and unlocks the doors of the renegade in the event of an accident. Fuel flow is also cut immediately.
Electronic Brake Force Distribution: Optimizes the Renegades braking forces by regulating pressure front to rear
Electronic Stability Control: Maintains the REnegades direction stability under all conditions
Electronic Roll Mitigation: A derivative of the Renegades Stability Control. Uses ESC sensors to detect roll risk, applies brakes, manages throttle.
911 Call Assist: Buttons on the mirrors for emergency services, roadside assistance and Uconnect Customer Care
All-Row Full Length Side Curtain Air Bags: Curtain airbags that extend to front and rear passengers. Each bag has a sensor to automatically trigger only in the place of impact
All Speed Traction Control: Self explanitory
ABS with Rough Road: ABS system is capable of understanding the type of driving surface, rough or off road surfaces engages a different pressure level of the ABS system
Automatic Defog: Automatic temperature control measures the renegades interior humidity and de fogs accordingly
Windows automatically reverse if they sense an obstruction
Blind Spot Monitor: Twin ultra wideband sensors monitor blind spots during reversing, changing lanes or being passed. Notifications come from illuminating icons in the side mirrors and a selectable chime.
Brake Assist: The system applies max braking force in an emergency situation
Brake Lock Differential: Allows the Renegade to maintain forward movement if one or two of the wheels experience slippage. The system automatically applies brakes to the spinning wheels
Brake-Throttle Override: Courtesy of Toyota, the Renegades brake pedal overrides the accelerator
Brake Traction Control: Applies braking force to the individual wheels weather its slippage during acceleration or low speeds
Forward Collision Warning: Uses radar a video sensors to measure Renegades approach to another vehicle or obstacle
Front Mounted Pelvic Airbags: Increased protection to the Renegades driver and front passenger, housed within the seat itself
Front Wiper Deicer: Prevents the Renegades wipers from freezing to the windshield
Hill Start Assist: Assists the Renegade when starting from a stop on a hill by maintaining brake pressure when your foot moves to the throttle
Hill Descent: Trailhawk only, mitigates decent at speeds from 1 to 5 mph
LanseSense: Lane Departure Warning
ParkSense: Rear park assist system
ParkView: Wide angle rearview camera
Ready Alert Braking: Anticipates an emergency braking situation and primes the calipers against the rotors to decrese the Renegades time to full pressure
Rear Cross Path: the Renegade will alert you when reversing from a parking spot if there are vehicles crossing behind you
Sentry Key: Engine immobilizer
Trailer Sway Control: cuts trailer sway and improves handling under towing. Fights cross wind conditions. Renegade monitors its movement relative to the drivers intended path. Uses alternating brake pressure to keep Renegade level
