I installed a Yakima rack, round bars with the front wind fairing to reduce noise and improve airflow. I will post pics tomorrow as we ran out of daylight. Did take it for a test drive and did not notice any noise. Pleased so far. The next step is to install my fishing rod rack on it. I have some rather large 1 piece surf rods that will not fit in the Renegade so up top they will go. I do need to open up the tubes a bit on the rod rack so I will sand the nylon inserts in the morning. One of my reels is wider than the others by about ¼" and won't fit.
Also had an oil change, oil filter, tire rotation done this morning (16,000 miles). They also flashed the ECM and PCM which took over an hour and a half. The tech said they large updates but didn't have any particular specifics. Shifting has always been good but it does seem a little smoother, maybe my imagination.
Also had to order a new clip that holds the hood rod in place when the hood is closed. The clip was always very, very tight and I figured it was just a matter of time before it broke. I was right.
