Anyone had this issue? On top of all my other issues I am now getting a warning intermittently that says "Service electronic parking brake"
that's horrible man! What else did you experience? Anything major?I've had issues with that warning light popping up randomly for a year now, its one of the many many issues I have, but the dealship has never been able to replicate it or fix it. I don't really have much advice, hopefully you have better luck resolving it than I have.
I get a ton of warning lights all the time, Svc 4wd, svc airbag, svc esc, svc parking brake, etc.that's horrible man! What else did you experience? Anything major?
Try disconnecting the negative battery terminal for 45 minutes and reconnect.Hi guys,
Purchased my Trailhawk and started having a problem in the first day. When I am driving, the electronic brake warning comes up and the red brake light flashes.
The brake button below the gear keeps flashing in an irregular way like there is a connection issue somewhere
I've done that multiple times with mine, I've even left it disconnected overnight numerous times and it's never fixed the problem, neither have the 12 or so dealer visits and the almost 60 days total not its been in the shop throughout all the visits.Try disconnecting the negative battery terminal for 45 minutes and reconnect.Hi guys,
This seems to fix general sensor issues. If it persists, take it to the dealer.
Hope you get it solved!
Hi ozgunique,Hi guys,
That seems dangerous, looks like they need to replace your car with a new oneI get a ton of warning lights all the time, Svc 4wd, svc airbag, svc esc, svc parking brake, etc.that's horrible man! What else did you experience? Anything major?
My traction control light randomly comes on and I lose power/throttle response for around 10 seconds. This problem is fairly new.
Lately my trailhawk just randomly shuts off.
I had to have the brake rotors and pads replaced at 2k miles because the pads were coming apart according to the dealer.
I randomly get a misfire code for one of the cylinders.
And finally the dealership had to replace part of the wiring harness for the IAT sensor because it quit working. So yeah, I've had a lot of issues.
Thanks for the advice! Don't want to do anything on my own, the dealers sometimes give you trouble for touching anything.Try disconnecting the negative battery terminal for 45 minutes and reconnect.Hi guys,
Hi Erica,Hi ozgunique,Hi guys,
I'm so sorry to hear about this! Have you brought this to your local dealership's attention?
Erica
FCA Social Care Specialist
Intermittent problems are a barrel of fun. Had my fair share of chasing them in the past.Sounds like a faulty connection somewhere could be a bad earth ... garage computer can't always detect this .. I bet it's something simple to fix .. problem is finding it .. especially if the faults are intermittent ..
I had to replace a battery once that caused problems ..
I agree. I got nowhere with FCA though so all my documentation has been given to an attorney and I will have to wait and see what they end up working out with FCA.That seems dangerous, looks like they need to replace your car with a new oneI get a ton of warning lights all the time, Svc 4wd, svc airbag, svc esc, svc parking brake, etc.that's horrible man! What else did you experience? Anything major?
Removing the negative battery terminal will not affect your warranty. It is YOUR Jeep after all!Thanks for the advice! Don't want to do anything on my own, the dealers sometimes give you trouble for touching anything.
ok so do I just release the latch and take the cable out and wait for a while?Removing the negative battery terminal will not affect your warranty. It is YOUR Jeep after all!Thanks for the advice! Don't want to do anything on my own, the dealers sometimes give you trouble for touching anything.![]()
