I removed these heatshields from my wife's 2021 Jeep Renegade Trailhawk with 1.3L turbo engine. I'm including a custom DEI heatshield for the intake bridge/snorkel as well! These two products made a noticeable difference in reducing under-hood temperatures along with increasing the engine's throttle response, especially during hot summer months! Both are in good condition and ready to install. Quick & simple bolt-on design with basic hand tools (T30 Torx bit and a 10mm socket or wrench) making it an easy DIY job. I originally purchased the turbo blanket from Renegade Ready/Madness Autoworks near Austin, TX. I will pay shipping charges for USPS Priority! I know I am a new member here, but for anyone who wants to dig into me a bit, I go by Kracka on EvolutionM (former moderator) and CorvetteForum. I also have a 100% rating on eBay (CivicBoy82). Thank you!
Reduce the heat in the engine bay of your turbocharged Jeep Renegade and boost the performance at the same time with this Premium Titanium Thermal Turbo Blanket.
Installing a thermal blanket like this on your turbo charged vehicle is one of the most cost-effective power increasing modifications you can make. Remember, decreased temperatures under the hood mean better radiator performance, cooler intake charges, and extended life for things like wire harnesses, fittings and vacuum lines. You can also expect power and torque increases in addition to decreases in spool time of your turbo.
The theory behind this upgrade is rather simple. As you may already know heat is energy and gas will expand as it becomes hotter. The more heat you can keep inside the turbine housing the better. The heat that is retained in the turbine housing allows for more pressure to be directed through a turbine wheel which will improve the performance and increase the overall boost pressure while at the same time decrease the time it takes to build pressure.
Features:
Heat tolerance specs:
Interior Surface:
Maximum Temperature Rating: 2325°F/ 1270℃
Continuous Use Limit: 1835°F/ 1000℃
Exterior Surface:
Direct Contact Limit: 1810°F/ 989℃
Radiant Heat Limit: 2475°F/ 1378℃
Features:
- Designed for the Jeep Renegade with a 1.3L Turbo Multi Air Motor
- Not a generic blanket
- Bolt On Installation
- Fully Reversible
- Designed to reduce under the hood temperatures
- Helps the turbo to spool up quicker for improved performance
- Reduces thermal loss
- Helps to maintain the velocity of the exhaust gases
- Protects vital under hood components from high engine heat
- Multi Layer Construction
- Titanium Fabric Outer Shell
- Calcium Magnesium Silicate Wool Inner Core
- High Temperature Silica Fabric
- Stainless Steel Capstan Rivets
Interior Surface:
Exterior Surface:
