1 - 12 of 12 Posts
Hi all! I’m a new Renegade owner. 2019 Latitude. Loving it so far. I want to change out my factory rims for some Raceline 17”x7.5”. My current tires are 215/60 R17.
Will the new rims work with my current tires? Also I have the option of 17mm or 20mm spacers. Which would be best? Thanks in advance for your help!
and enjoy the forum!
Search is your friend!
All the info you need is on our forum! Click me Click me!
Yes, your tires will work.
Spacers, it would depend on the backspacing of your new rims. for example: 17X7.5 30mm offset. 3/4 to 1 inch is about as far as you would want to go with a 30mm offset.
17mm = 5/8"
19mm = 3/4"
26mm = 1.00"
32mm = 1.25"
38mm = 1.50"
**conversions are -ish, but close.
I like the idea of a little bit wider tire then the rim to protect the rim from rocks them off roading.
1 - 12 of 12 Posts
