I'm in the UK and had a can of goo and compressor with mine. Ideally I'd like a full size steel but bought a space saver and higher boot floor from the dealer. Not ideal.Not in UK. Ive a Steel Spare. Its a Full Size, same tyres as on the 4 wheels (Goodyear 4 Seasons Mud and Snow) but on a steel.
hi Oggy, sorry yes I should have mentioned I ordered the optional full size spare, for my Trailhawk.I'm in the UK and had a can of goo and compressor with mine. Ideally I'd like a full size steel but bought a space saver and higher boot floor from the dealer. Not ideal.
If the car included a jack I would take one off and check if it fits, but the cheapo FCA didn't include it.When I picked up mine I had them put the skinny + jack kit in. 190 Euros inc taxes.
My understanding was that a full sized 18" wheel will not fit in the well.
But the kit comes with 2 retaining bolts: One for skinny and a longer one for a full sized.
Maybe the best thing to do would be to take one of your 18s off and see if it fits.
Maybe it's only that it doesn't sit flush?
Just got a call back from another dealer and they said since mine is an AWD the kit is not ok to use because it will ruin the AWD system and I should just go to a tire store and get a similar size wheel and tire that will be identical to mine and buy a universal jack / tool kit as well.I got the 2017 Renegade Altitude edition with 18-inch tires, and I am really uncomfortable with the tire kit without a spare tire and jack. Not driving like a maniac, but if the tire gets ripped in the backcountry, the kit is useless.
Called one dealership, and they say the kit # 82214679AC is not compatible with my car. Called another dealership and they say its just a doughnut and its ok to drive it if the tire is much smaller than the other 18 inch tires. Called Jeep customer service and they said the part is not showing up against my VIN so it is not compatible, but to go to the dealership that said it does and they will be liable... Are they kidding me? this is very confusing.
Are you a renegade owner with 18-inch tires? what did you do for a spare (and parts needed like a jack etc.)?
Full size spare has a different tray under the cargo floor. You'd likely have to ditch the tray depending on how it is designed. The floor would move up to the raised notch compared to the no-spare setup unless they changed the way it works in the 17.Hey guys, I have one more quick question
Will a spare tire fit in the wheel well inside the Renegade Sport? Right now it currently has the tire repair kit with inflator.
Thanks again
That is exactly what I did to fit my full-sized spare - works well!Full size spare has a different tray under the cargo floor. You'd likely have to ditch the tray depending on how it is designed. The floor would move up to the raised notch compared to the no-spare setup unless they changed the way it works in the 17.
