Took some pictures of our 2015 Jeep Renegade Trailhawk's casting marks on the backside of the spare matching aluminum wheel.
Description and pictures follow:
First of five spokes:
6A1S17Mg
MOPAR
X (circled)
T6 (circled)
Second of five spokes:
3621 (I think)
735577526
6.5Jx17H2
OFF 40
Third:
E-DOT
POLAND
D782
Fourth:
15|ॱ| | | | (pattern is five lines, a dot high between the leftmost line and next one)
14|⋮|⋮|⋮|⋮| (pattern is five lines, four vertical ellipses between the lines)
Fifth:
Raised circle containing 7/3 stamped-in
Raised circle containing 17 stamped-in
4 (circled)
0 (circled)
I measured an inside diameter of the aluminum wheel at the backside bead of 16-7/8" or 426mm, and a traditional "backspacing" of 5-3/8" or 137mm. The inner diameter of the wheel at the hub is 15-1/4" or about 385mm.
Donno if this helps anyone or not, but figured it might. I'm assuming that 735577526 is a part number, while the 6.5Jx17H2 / OFF 40 describes the wheel dimensions in fractional units and the offset in millimeters.
6A1S17Mg
MOPAR
X (circled)
T6 (circled)
3621 (I think)
735577526
6.5Jx17H2
OFF 40
Third:
E-DOT
POLAND
D782
Fourth:
Fifth:
4 (circled)
0 (circled)
