1 - 4 of 4 Posts
I have an ATP 2 inch lift in my renegade and one of the sway bar links has gone bad. They are 2 inches shorter than stock and ATP is way behind on products so I can't get replacement units from them at this time. Anyone have an idea for a replacement?
Whiteline makes adjustable length sway bar links. Probably more costly, but if you need them now you might find something that works. You would need to know the length and diameter of the current ones and find a pair that matches up.
cut and weld any metal aftermarket links ?
Ouch that hurts to read that concept.
There are many good welders out there that will be aghast at cutting and welding factory manufactured parts.
I was ASME coded years ago and I don't think it's a good idea. A dangerous idea? yeah.
Buy the correct parts and drive safe.
1 - 4 of 4 Posts
